Hertz HDP4 need help
Set the high pass on the head unit to 80-100hz
Set the low pass on the amp for the mids to 3500ish
Turn on the x10 switch and set the high pass for the tweeters to 3500ish.
That's a good start. Most tweeters will play that, ideally you want to bring the tweeters down to 2500 IF they can do it. Only good ones can. If you lower the tweeters also lower the low pass for the mids the same.
Then you can't run active with no way to cut off the low end of the mid. You will have to use the amps HPF there so you won't be able to cut off the top end of the mid.
I figured that deck would have a HPF. It's pretty standard these days.
If it truly don't have one then bridge the amp and run passive.
Then you can't run active with no way to cut off the low end of the mid. You will have to use the amps HPF there so you won't be able to cut off the top end of the mid. I figured that deck would have a HPF. It's pretty standard these days.
Would bridging make senses with these speakers?
It seems I need to properly install the parking breaks and emergency wires to get to that menu. I am not sure where thoses wires are on my car.
On my car 2010 hyundai accent anyone got a clue where to find these wires?
It seems I need to properly install the parking breaks and emergency wires to get to that menu. I am not sure where thoses wires are on my car.On my car 2010 hyundai accent anyone got a clue where to find these wires?
They have a bypass. Look up Alpine video bypass. It's a little box
alex1002
alex1002
Toronto, CA
LosIsATool
