But do you have the electrical to sustain it?well unless you can name an amp 450 dollars or less that is PROVEN to do .35 daily and put out the same range of power(2000+), ill stick with a 20.1 for now.
American Bass 75.1 nub.well unless you can name an amp 450 dollars or less that is PROVEN to do .35 daily and put out the same range of power(2000+), ill stick with a 20.1 for now.
I have a 220A alt and a pair of Yellow Tops, and still got voltage drops under 12v with my 20.1 wired to half an ohm... They are no where near 'efficient', but beastly none the less.But do you have the electrical to sustain it?
I dont see .35 ohm stable for daily...
info from another thread.A 20.1 will work well for the 1.4 to .35 DD to burp setup on that voltage.IIRC, Noah had decent luck with the kicker 2500 running at both impedances. Its output can be more then a 20.1
MMats and DD amps work well for this. As well as the AB and VFL amps. An AB 75.1 would be a good match up for you too if you wanted to save some cash. It "could" be ran at .35 all the time.
i just hope you understand that your amp will see that .35 load for a split second at least and that could be enough to say good night.well, the sub had already been shipped out. he told me to just try it out and see how my amp handles it. he said the minimum i should see after impedance rise is .75 and i know the herc could handle that daily. if the amp seems to be overheating badly then i'll send the sub in for a dual .7 recone.
Says on ROE over 2300 watts. I think Jntar knows about it I quoted him earlier in this thread.Suburban what does a 75.1 do @ .35? thats one of the ones Im looking at if I dont get my orion 2500D
well jntar also said the kicker 2500.1 will do .35 and pretty much everyone that owned one in the same thread said that amp will fry on .35 ohms. I tohught you were speaking form actual knowledge.Says on ROE over 2300 watts. I think Jntar knows about it I quoted him earlier in this thread.
strangeI have a 220A alt and a pair of Yellow Tops, and still got voltage drops under 12v with my 20.1 wired to half an ohm... They are no where near 'efficient', but beastly none the less.
