thormxkid 10+ year member Senior VIP Member 168 0 ontario Feb 1, 2009 #1 i have two 10 inch kick cvr in sperate truck boxes with sub both 2 ohm how would i hook them up to run a 2ohm load on the amp Click to read more...
Bass Addict 10+ year member Hell on wheels 1,977 298 Tennessee Feb 1, 2009 #2 wire them to 4 ohm each so the amp see's a 2 ohm load
OP thormxkid 10+ year member Senior VIP Member 168 0 ontario Feb 1, 2009 Thread Starter #3 and how would i do that ...btw there single vioce coil 2 ohms
shaneb 10+ year member CarAudio.com Veteran 2,559 0 Fort Worth, TX Feb 1, 2009 #4 If they are SVC 2ohm you can only run them in 4 ohms or 1 ohm.
A AudioJunkie73 10+ year member Member 104 0 new Orleans Feb 1, 2009 #5 what kind of amp you have? If its a two channel amp run each one to each channel. If its a mono amp then you have to run then in series to 4 ohms.. Unless your amp can handle 1 ohm then run them in parallel.
OP thormxkid 10+ year member Senior VIP Member 168 0 ontario Feb 1, 2009 Thread Starter #6 ok so how would i wire it to 4 ohms then because my amp can't run 1ohm stable
91Chevy 10+ year member Resident Metalhead 674 0 Vernon, BC Feb 1, 2009 #7 http://www.crutchfield.com/S-lc1ISnOflmM/learn/learningcenter/car/subwoofers_wiring.html Holy shit it's hard to use google.
