have dls up6 coponent set drivin by dls ultimate A3 for front stage and 15L7 with kx1200.1 for sub. I had it all installed and when it was done the guy told me he left my center channel (to the stock amp) in because the components werent loud enough he said they are more for SQL. But they handle 150w rms a peice and the amp pushes out 1200w @ 1ohm so its pretty powerfull component set. Now my center channel is WAY louder then my components (i cant even hear them) unless i turn the volume WAY up but then it clips the center and sounds bad. What I wound up doing is going to the EQ and putting high mid and low as low as possible this way when i turn it up it wont be loud in the center where i can actually hear my components. I need max volume on my hu to hear my components and it dont sound good. it seems like they dont kick on or something but with that huge amp etc i dono whats wrong. When I have a normal EQ setting and i have the volume descently loud I ONLY hear the center! What should I do?
I have an amp for my component set that can power my sub (1200 @1ohm) and a factory speaker is tripple its volume? There HAS to be something wrong
