help zane!!
slick rick
OG
ok, i have the mtx 102 amp, its rms power at 2 ohms is 50x2, the peak is 125x2 @2 ohms. now bridged its at 250 peak, 100 rms. id like 2 get 2 kicker comp 10" subs, will this amp be good enough 4 them, and if it is, wuld bridging it be worth it, they wuld go in a small sealed enclosure. also what ohm subs shuld i get if i do? thanx, every1 talks about u so i figured id ask u mainly 4 help on this 1.
Well they will push one to its max and yea it will push two but not to thier max they will sound ok if you get get two 4ohms then just wire them into a 2ohm load and that should do it to were they thump decent or until you get a new amp.
take it easy,
-zane
slick rick
OG
slick rick
Violates Miranda
zane
ThxOne
    Aug 15, 2026
TechGuru88
    Aug 10, 2026
