Help with torres?
Austinw88
I know this get's asked a lot and I did a little searching and came up with no answer to my problems, I get everything put in like I think it should. But when i do the port everyone useually recommends 16sq inches of port, I never come close to it. If I do come close to it by changing things it throws my tuning waaay out into the mid low 20s. heres what I have.
Outer Dimensions
height: 16"
Width: 40"
depth: 20"
port dimensions
Height: 14.5"
Width: 4"
Length: 26"
what I come up with is
4.33 sq ft
13.39 sq in of port per cube total of 58.00sq inches
Tuning frequency is 33.43??
I'm looking to get 4Sq ft net volume tuned to 32hz with 16 sq inches per cube, what am I doing wrong?
Outer Dimensions
height: 16"
Width: 40"
depth: 20"
port dimensions
Height: 14.5"
Width: 4"
Length: 26"
4.33 sq ft
What you came up with should be enough port area unless you have very powerful subs on quite a bit of power.
176
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
533
375
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
364
Austinw88
Austinw88
South Carolina
T3mpest
    May 16, 2024
    May 16, 2024
