Help With T1's Need A Good Amp
2 Dual 4 ohm subs will give the amp either a 1 or 4 ohm load.
If you have it wired to 1ohm, that amp is NOT 1ohm stable, if you have them wired to 4ohms, you wont be getting all 1000w to your subs.
The problem is, is that the amp only puts out its 1000w @ 2 ohms.
You can ONLY get a 2ohm load if you have 2 dual 2 ohm subs.
So you either need to get a set of dual 2 ohm subs, or get an amp thats 1ohm stable.
Jbowsky_62
Jbowsky_62
Beaumont, Tx
skateboardkid
