Mikealano1
i have 2 12" lanzar maxpro subs 2000watts total in a ported box with a xplod 760watt amp hooked up to it is this ok? bigger amp needed? if so what kind should i get thats not to pricey. thanks for feed back
This, if you can at least. Those subs can probably handle around 400w each. If you can't send them back look for an amp that does around 800w @ 2 ohms (those subs should be single 4 ohm each).I would take that stuff back to the pawn shop you got it from and get your $30.00 back. Then browse the classifieds on here and get some decent gear.
audiopipe>hfi series amps. brz>AP the hfi line is trashI think the Lanzar Max Pros are DVC 4 ohm subs......I would prob try to find me something that does 800-1k @ 1 ohm and run with it!!!! Maybe Audiopipe or Hifonics HFI series.
