help with subs
Forget the cap, and get yellow tops instead of red tops. Look at deka instead of the optimas. Type Rs are not bad for the money, I would maybe look a bit further. Amps great selection. Front comps, I would definetly look at more options, maybe ID, and I would not mix brands on the comps. Hope that helps.
yellow tops it is then.... from most of the reading i've done its hard to beat the spx-17pro's for the money.. how are the spr-17cs's for the rear doors? i'm also still up in the air on cutting my brandnew truck up to do 4 of those bad boys.. i know i can do 2 with the back seat removed but i think 2 would be a waist of my amp.... witch ID's did u have in mind?? also will i need more than my 4 door speakers to keep from being drouned out by the subs??
shadys281
shadys281
shreveport, La
shadys281
