Help with schematics or wiring diagram for No name 2 DIN multimedia
  • 4
daga
Hi guys,
I got a used No name 2 DIN multimedia, but there is no ISO adapter with it. So now I can't connect it to my car.
On the top of the unit there is a schematics but isn't full explained. I'll attach them, so if you can help me. I can't understand which cable to which pin must go. Thank you for the help, and excuse me for my bad english.
OK. But how I can find for what car is made? If I know that I will may be find a pinout wiring for it. I know that will not fit perfectly in my car.
And I think so. Closest head unit to that I have is from Hyundai Sonata 2009-2010. May be that I have is some chineis imitation. I find over the net a few links, but on them there is no model,no brand, no noting.
Here is what I find so far
For the speakers yes the rest of it good ?. Either way it won't work because most of those OEM head units have codes in them that lock them to their Original ECU/Computer. Worked in Auto Parts a long time and had to deal with this quite a bit.
You can power it up but I am telling you it WILL NOT WORK in your car. That unit is locked to the OEM car it came with even if you power it up it will not function properly if at all.
Look at the schematic it says black ground yellow battery and red 12v. Same as any other head unit. Good luck but if you do this you may end up screwing something in your electrical system as it wasn't made for your car.
The color is OK. But on the schematic you can't understand what color on what pin on the adapter must be. Are you follow what I want to say ? Also there is no risk for screw something in the electrical system at my car, becouse I'll connected it at my home with power 12V power supply just for testing. I will not connect speakers and etc before I see that work OK. So once again I need to find which color on the connector to which pin on the unit must connect
This is a replacement wiring harness that plugs into the back of that radio. You can take the part number from scosche FD23RB and go from there.
Your best bet is to buy one of these locally and then plug it in. Each wire is color coded and has what it does typed on it in english or if you are lucky enough your language
edit: idk why it says security check but it goes to carid.com and has the harness you are looking for
or type in Scosche FD23RB as said above in the 1st sentence
Do you mean that connector ? If so - the connector no way to fit in the unit
P.S. I find that site - https://pinoutguide.com/ , if I only know from which car the unit is from I will find the pinout schematics
I think I find some like may be work,but which one ?!
So I was able to start it. But theare is a problem - when start, the screen is blank,no logo,no icons,no menu,no noting. When press the buttons they beeped but noting happend. Only when I turn volum up or down shows the current level on volume. Bass also can adjust but that's all. What can be the problem ?
270
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
270
511
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
319
daga
daga
Sofia, Bulgaria
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
