Help with my audioque 3500.1
RealTime
4
CA
Hey, trying to see if someone could help me on fusing mu Audioque 3500.1D. The amp has to positive and negative power wire inputs going into it. It is rated for a 380 amp fuse. A rep at AQ said that I would very seldom draw a 380 amps and that I can use a 250 amp or 300 amp fuse with it. my question is, since it has two separate positives going into the amp...would I wire each side with 150 amp fuses or 200 amp fuses???? Thx
you want at least a 350 amp fuse under the hood and then use a distro or split the runs from your secondary battery. How many runs of 0g do you plan to run? I dont have any experience in 2000w+ setups so keep that in mind.
I have 3 runs from the front battery to the rear battery all fused at 300 amps (0/1 size). Now from the rear battery to the amp what should I do? I need to run two 0/1 runs for positive and negative to the amp. So how would I fuse both positive going into the amp?
AQ no longer has any technical savvy reps, so unfortunately I would not consider much of anything anyone there says other then the price you get quoted for items.
RealTime
RealTime
CA
RangerDangerV2
