help with front stage
PUREAUDIO
Hello all, im starting to plan my build for the winter. First off ill tell you what i have and plan on getting then hopefully you guys can help with my dilemma ( my front stage ) This is all going in a 2013 single cab GMC Sierra with lots and lots of sound deaden and electrical upgrades to support the system. The equipment i have is as follows 1-Lunar L450 4-ch amp (50x4@ 4ohm) and 1-Lunar L1500 mono amp (500x1@ 1ohm) 1 set of HAT Legatia L1v2, 1 set of HAT Legatia L3 and 1-TC Sounds 12''svc underhung subwoofer aka Audiomobile MASS 2012. This is what i plan on adding, a Rockford Fosgate 3sixty.3 signal processor, 2-10'' Clarus C10SW-D2 by HAT and run my Lunar L1500 @.5ohms. The H/U is TBD later.
So you can see im off to a good start well i think so hehe. The plan is to run highs and mids up in the a-pillers and the midbass in the doors.
As for my front stage should i ditch the HAT i have now and get the HAT L3SE and HAT L6 or L8 and run no tweet? Or ditch the HAT L3 and get the HAT L6 and use the HAT L1v2? Or use what i have and hope the HAT 10'' help with the midbass? Or any other options you guys might add?
Thanks in advance
PUREAUDIO
PUREAUDIO
LOUISIANA
PUREAUDIO
