Help with AVIC n1
babyloc86
SFV, CA
i juss got my avic-n1 installed professional installer yesterday, well....first off, he couldnt find the speed censor wire for my 98 2.3 CL. do you guys know where that wire is and what color that is? also when i tried my navigation, it totally off where i am off by a block plus its not pointing at the right direction where im going where it suppose to. my guide mode doesnt work and this other mode doesnt work for navigation. do u know what would be the problem is? are those problem caused becaused i dont have my speed censor connected?
i would apprieciate you guys help.
A. The installer that you had to your install doensn't sound all that professional to me.
B. Most likely the installer didn't orient the hide-away or "brain" correctly. It must be mounted in a certain direction in order for the internal gyroscope to work correctly. The funny part is there are big ass arrows on top of the brain to tell you which way to mount it.
C. The block off thing could be related to where he mounted the GPS antenna. Where?
D. I will check Directeds Database tomorrow if i can remember and let you know about the VSS Wire.
A. The installer that you had to your install doensn't sound all that professional to me.B. Most likely the installer didn't orient the hide-away or "brain" correctly. It must be mounted in a certain direction in order for the internal gyroscope to work correctly. The funny part is there are big ass arrows on top of the brain to tell you which way to mount it.
thx alot man.
because if it is used that increases the chances of the unit being bad... but yeah like chrye said... the unit has to be facing a certain direction for the arrow to show you the correct direction... are you inserting the navigation disc? i've had mine installed since a mid december... and it's working fine with no speed sensor connected... no wiring diagram had one for my car yet... but it still shows my speed and everything works perfectly...
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
121
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
434
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
408
babyloc86
babyloc86
SFV, CA
SentraStyle
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
