Help with amp
SQL4Life
Hello all... i am getting a set of pioneer revs coaxials (60 rms) for the front ( no rearfill) and a sub pushing 5-600 watts... can i buy one amp to power both? i need a four channel amp im guessing but any suggestions?
Example. if i use a cadence 6004
150 x 4 @ 4 Ohm
300 x 4 @ 2 Ohm
600 x 2 @ 4 Ohm
can i somehow give the sub 600 watts at 4 ohms and then the speakers 75 watts? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
i was gonna get a phoenix gold rsd ( im on a budget...college+ marriage = ouch) i see the dvc's everywhere im sure i can find a svc if need be
it can be done. Bridge 2 channels and use the other 2 channels normally. Many 4 channel amps are capable of this. have you actually decided on the cadence 6004?
No i have not decided yet but am very close to if i know that i won't be sending too much wattage to the pioneer revs ( 60 watt rms) and enough to power the sub ( phoenix gold rsd, 500 rms)
do you recommend an amp or have something else in mind Devillain?
Thanks for your help
Maybe you could find an orion amp. Like an 8004. WHats your budget?
Look at rockford, Hifonics, the older orion amps. Thats just where I would start. With the 8004 at the top of the list.
and no problem.
SQL4Life
SQL4Life
U.S.A.
Chevillac
