So you have
Powering comming from a 12V source,
then to the input side of a Toggle Switch
From output side of a toggle switch
to the remote input on said Amp???
Hopefully, if you are doing stuff like this you have a Voltmeter and a Test Light and are know how to work'em...
1. Take test light verify your source actually has and is suplpying 12V, if it has power move on to the next step.
2. Next test for 12V @ Input side of Toggle, if it has power move on to the next step.
3. Next test for 12V @ Output Side of your Toggle, if it has power move on to the next step.
4. Next test for 12V @ the Remote Input terminal on the Amp, if it now has power you have other issues...
Verify that you have power at the amp.
If you do, does the amp have any lights that come on?
Either way, if your power (remote and supply) is 100% squared away, your amp may be now having Issues...
Other than that, theres not really much else...
