T tonyisgay 10+ year member Junior Member 10 0 Kentucky Dec 18, 2008 #1 im buying two 10 inch kicker cvt shallow mount will the kicker 750.1 mono amp work with these? will it run hott? Click to read more...
subfrontier 10+ year member Lunar Amplifiers 166 0 Louisiana Dec 18, 2008 #2 If the subs are single 4ohm each you will be fine. that amp should be more then enough power,
D dB-r 10+ year member CarAudio.com Elite 1,294 6 Texas Dec 19, 2008 #3 Yep, more than enough power... heat will depend on how long you run it at full volume and also if your voltage drops down much when you are running it hard....
