help with amp clamping...
Looks like those should work. To be honest, I have never tried to measure true RMS watts & calculate impedance rise, but I found a decent explanation on another forum...
"Use the True-RMS Clamp Meter on the +speaker wire only to measure your AC Amperage and use a DMM with peak-hold on to measure AC Voltage across the speaker +/- terminals.
Multiply those 2 numbers to get your RMS Wattage.
To find the Impedance rise you divide the voltage by the amperage. NOTE - impedance rise varies with frequency, so the measurement may depend somewhat on the test signal you are using. "
Multiplying those number will give you VA - 'not' RMS wattage.
To get wattage, you would need to know the phase angle as well - which is a bit more involved...
For comparison purposes - VA is usually sufficient - just clarifying that the number you get is not the actual wattage.
can you recommend a cheaper clamp meter?
raptor727
come get some!!
raptor727
pensacola FL
n8skow
