help with algebra problem
just cant remember how to do this, someone help lol
need the slope of the line passing through each pair of points or state if its undefined. then indicate whether the line thru the points rises, falls, is horizontal, or is vertical.
question:
passting through (4, -7) and parallel to the line whose equation is 3x + y - 9 = 0
I think you could do X1 minus X2 divided by Y1-Y2 and that is your slope, but you can then times that by 2 and that would be parallel. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
What the **** grade are you in anyways?
question:
rewrite 3x + y - 9 = 0 as y = -3x+9
the slope of that line is -3. the slope of the new line will also be -3
to solve for the equation use:
y=-3*x+b with x and y from the point in the question. Solve for b. done
edit: wait a second they don't want the equation of the line all they want is the slope and if it's upward or downwards. That should be easy: m=-3, falls
I was on the right track when I said it needed to be in slope intercept form.
This is when this will come in handy in real life. To school people on ca.com
this is what the back of the book gives for an answer. basically you have to show work/explain HOW you get the answer
Answer: y + 7 = -3(x - 4); y = -3x + 5
ufvj2172
Banned
ufvj2172
FL
ufvj2172
