pi * radius^2 * lengthwell like i said the internal volume is 5.6 before sub and ports as the calculators say so but im confused when it comes to figuring out how much area the ports are taking up. unless someone could tell me. i guess ill start with 3 4" ports at 12" to 14" and see how it sounds. hope all goes well
This is how I figure out the displacement of the aero ports. I've seen and metered some decent enclosures with 15" subs, one with three 4" aero's, and one with our 4" aero's. They both had respectable numbers for the power used and I didn't see any noticeable difference between 3 or 4 ports. You will just have to take into account the size of the enclosure, the tuning freq you want and how much space you want to displace. I'd say go with three 4" aero's and tune them to the freq you want. Then figure out how long they will need to be to play the peak freq of your vehicle for doing an SPL comp. You should be able to swap out the ports as needed for doing a comp and then going back to playing music.You use the formula to find the volume of a cylinder, use the ports as a cylinder and there ya go.
