I think he said that he was trying to use voltage sence and I believe that he is having problems accessing the program menu to change it to voltage sence. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifi think he means he's trying to program the tach, not get into programming menus..
and if this is the case I think he's confused what tach/tachless actually means. that or typo
trying to use tachless.
this is the programming technique for learning tach if you were to run one from the vehicle. IF you are doing voltage sense you do not need to do this, you just need to set the crank timetried to program by starting the vehicle and within 5 seconds press and hold the valet button and its supposed to stay solid within a few seconds
what? do you mean if he IS doing starter kill?green needs to be hooked up if your not doing the starter kill.
are you ok? I know you know your shyt, but you got it backwards, dude!! //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gifthen purple key side and green starter side if you are doing the starter kill. those could be backwards.
