help with 3way crossover set points
yea thats what i plan to do midbass in the doors, mids in the kicks and the twets in the pillars
I'm not sure how well those Founteks will like 160hz. Might as well bump it up to 200 or 250, since the SLS can handle being crossed a little higher than 160, and you'll gain more power handling on the Founteks at the same time. And don't cross the tweeter low just because you can. It can be crossed at 2k but the real benefit of a 3-way front stage is having the majority of the vocal range coming from one set of speakers, the midranges. Crossing tweeters at 2k just kill that advantage...might as well just have a 2-way.
good advice
ill make the midbass 60hz to 250hz
midbass 250Hz to 2.5Khz
Tweeter 2.5khz and up
how does that look?
BTW: im still looking for mids
B&C 6MDN44
http://www.usspeaker.com/B&C-6MDN44-1.htm
or
B&C 6 PEV13 it has 99dB Sensitivity
http://www.usspeaker.com/homepage.htm
or
SEAS Excel W15LY-001 Nextel Coated
and SEAS Excel W15CY-001 magnesium Cone
You are going about this all wrong. Don't predetermine anything it will just make it take way longer to dial in. Instead get things mounted and play your mids alone, get them dialed and then fill in with the tweeter and midbass.
im just trying to get a general idea with the crossover points, cause im still trying to decide with which mids im going to go with
good adviceill make the midbass 60hz to 250hz
how does that look?
B&C 6MDN44
or
or
The B&C is far and away too sensative for the rest of your system. You'd have to turn gains WAYYY down and still problem have level matching problems, plus when your midbasses and tweet were out of steam your mid would just be breaking a sweat. I'd go with one of the SEAS drivers over the B&C in your case.
That's just silly. There are numerous things wrong with all of the assumptions you just made. Are all sensitivity measurments = across manufacturers? No. What about baffle diffraction? Off axis listening effects? Amp efficiency?
Also, why can't one effectively level match where it counts? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif Don't choose speakers based on efficiency, bad idea.
M5 has it right; you're trying to predict the weather half way across the world, man. You need to go to the destination first and then decide if you need a coat or not. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I've done a lot of experimentation with the deep chamber Illuminator RR's in my car. Just cause they have a low Fs doesn't mean they will play low and sound good. 2khz was the lower limit for my comfort.
Also, if you've never used a ring radiator tweet, you're best finding a laser pointer to work aiming. 15* makes a major difference. But once you nail those tweeters, I doubt you've ever hear anything better - home audio or otherwise. They're beautiful!
And from my experience with pro audio drivers, they're not going to have the "finesse" you're probably used to with car audio speakers. They're designed to play in cabinets and play loud. I wouldn't say ultra resolution is their strong point; but low distortion and midbass snap they have in spades.
ty for your advise guys
Ill mount the speakers first, play the mids by it self try to dialed them in and then fill in with the tweeter and midbass.
since the B&C mids are not a good match ill get the SEAS Excel W15LY-001
How much room for a sealed kick do you have? Any idea how large of a Vb it will end up?
You really should model your candidates to see which will play best, in what I'm guessing will be, a small sealed kick...if you haven't already.
it is going to be small sealed kicks, if i use the Seas Excel W15LY-001
but if i use Fountek FR135EX, WLDock over at DIYMA told me
"WinISD shows 3 dB down at about 88Hz in a 0.209 cu ft sealed enclosure for a Qtc of 0.71. "
.2 cubes is more than 5L. That's pretty big for "small sealed."
Might want to determine how large you can make the kicks, before you buy anything. The other option is just to make them as large as possible and then reduce the Vb to optimize the driver that calls for a smaller air space.
Put the Scan 12M on your list if you're going to play in Excel territory. They can play in very small enclosures and will run out at .707 Qtc in like a .7L sealed. Might even be able to go dash/bottom of A pillar if you're game.
BlackMaxima
BlackMaxima
LA
ice_audioworks
