Help with 07 Scion TC
Anonymous
I installed a system today in it and i kept the stock head unit so i wired it through a line level converter and ran it to the door speakers. I fuse the remote with the sunroof fuse and before the the ACC fuse and both times whenever i turn the car off the amp stays on. Does anyone have any experience with this car or suggestions on what fuse i should use please tell me and also whenever the car is turned off if i hit the doors the subs make a noise and if the car if off and all the windows and doors are close, key out of the car the subs will just start bumping just bass, Help!
hahahahaahha never heard of that... how long did the amp stay on?? indefinantly or just for a short time?
You ain't looking for a fuse, you are looking for a relay which id kinda silly cause all you need to do is find a fuse in the fuse box that says acc or ign. make sure to use a DMM
i checked the fuse box and originially had it connected to the acc but the amp remained on when the car was off. I went and fuse it to the cig fuse which took care of the problem.
Anonymous
Anonymous
Cantonment, FL
Anonymous
