Help wiring my dual 1.5 ohm dd
To wire to 3Ω you connect a jumper from one coil's negative to the other coil's positive. Then you run the remaining negative and positive to the amplifier. It doesn't matter which + & - you jumper, as long as they're not on the same coil.
this doesn't show 1.5 wiring
it doesn't matter. You wire a DVC sub the same way regardless of impedance. Pick any impedance and you'll either be wiring it in series to raise it or parallel to drop it. If you want to wire it to 3 ohms you'll be wiring in series.
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
540
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
935
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
979
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
The Audio Guy
Chicago
Nutdawg651
    May 18, 2024
    May 18, 2024
