HELP what do u think????
  • 4
CaddyLacGrills
ok what do u think about this set up
Rockfordfosgate 1200 watt amp
1200W peak power @ 4 ohms, bridged
400W RMS (continuous) x 1 @ 4 ohms, bridged
200W RMS (continuous) x 2 @ 2 ohms
100W RMS (continuous) x 2 @ 4 ohms
and 2 kove armageddon m series 600 watt rms 4 ohm DVC subs
what u think and how do i wire it properly
__________________
Sounds like a pretty good setup to me. What kind of enclosure ? There are a couple ways to achieve basically the same thing.
Here is if you want to run the amp mono at 4ohm
And here is if you want to wire each sub to it's own channel. Wire each sub this same way.
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
yeah man. 4ohm dvc's wired like the first diagram. Will present the amp a 4ohm mono load. 400w x 1 at 4ohm
The second would present the amp a 2ohm load on each channel.
200w x 2 at 2ohm.
Which is obviously the same amount of power. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by CaddyLacGrills how do i get the full 1200 watts (600 watts to each sub)
to the subs?
You won't. The amp only states 400x1 t 4 ohms bridged, I would expect around 500 at 4 ohms on the birthsheet...
Did you buy the amp yet? I really think that is insufficient power for the Armageddons, especially if they are sealed.
that is peak power the amp will never produce that power. Look for somethting that puts out rms that is the true power.
I run CDT ES and HD drivers too, nice stuff!
52
currently I am using 4g wires for my ground and power (1-1.5ft for ground and like 16ft for my power) and no I did not sand the area for the...
8
103
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
226
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
694
CaddyLacGrills
CaddyLacGrills
twinsburg oh
ws140
1aespinoza
    May 19, 2024
1aespinoza
    May 19, 2024
