Help Tuneing please-Not a box
  • 2
rloring
oregon
OK First I am sorry if this is a long post, I know the community hates long post, but I have a few things I need some advice on....
First I need help in tuning my set up which is below in my Sig--
I have had my HU Imprinted which truly sounds amazing when I use the 2 loaded scopes I chose from the imprint, but this is for maximum SQ and really cuts back the DB,s more of just a Rollin supremacy setting .
Anyways I like to go full tilt as well, so I switch it off and the base drops the speakers sound like ass front stage is overbearing mid 6.5's distort center fill is non existent, I'm like WTF I try and set the crossover settings in the deck and mess with the EQ, I just don't understand all the settings
Can someone shed some light on what my settings should be,
my crossover menu reads as follows
LL--LR--ML-MR-HL-HR
which settings should these be @?, like what HRTZ for each?
what is a slope?, that one just confuses me
maybe someone who uses the same deck can help me out..
Also my amp,
Subsonic filter on/off???
Freq setting??
Punch EQ setting--not external
Gain, I have just about 1/4 over half
again sry for such a long post but I just cant seem to get it right thnx in advance guys
130
438
416
rloring
rloring
oregon
silvercookie
    Jun 1, 2024
    May 31, 2024
