i cant see the fuse, unless i take out the box and i have no idea how to do that since i didnt install it unless the fuse under my hood next to my battery is the amp fuse. i dont think the fuse is the problem tho.. cuz the blue hifonics logo on the amp lights up, but is VERY dim... i think it has to do with something with not enough power or something like that.
If you can see that your "hifonics logo" is lit but dim then you obviously can see if the fuses. They are thin, prong like fuses usually green they do not look like the fuse thats under your hood.
However, if your saying that the logo is lit, then that would indicate the Amp is getting power. If your Amp is getting power, then technically it should be enough power or at least send power to your subs. Yet, you are saying that the subs are not active at all...which would mean they aren't gettin power. So it has to be one of the following factors; electrical failure, wiring problem maybe loose connections , or a problem INTERNALLY in the Amp as I said before.
I really dont feel like it can be your battery, if your battery didn't have enough power it probably wouldn't start. You can start off by trying to give your battery some juice by either jump starting it, or if you can locate a recharger.
If that doesnt work, try disconnecting the subs and trying them in another vehicle with someone who has an Amp that you can wire it up right quick. That could eliminate if it is the subs. Then you can try the same thing with your Amp on another set of subs in a different vehicle.
Now it becomes a process of elimination, unless of course you just take it to a local shop and have them figure it out for you.
