HELP!! Subs cut out when turned up but protection doesn't come on.
Smoker076
Hi, I have 2 12" Cerwin Vega subs and a 1000 watt Cerwin Vega amp. I just bought these a couple weeks ago and hooked them up like I do any other time but when I turn the volume up past a certain point the subs cut out. I'm not sure if its something wrong with the amp or head unit because i've never had this problem. When they cut out the amp doesn't go into protection mode either. The green power light is still on and it acts like there is nothing wrong but the subs won't work until I turn it back down. Anyone have some advice?
I have turned the gain all the way down and turned up the head unit and no matter what i do with the settings on the amp it does the same thing. even with the gain, bass and frequency turned all the way down
Sony CDX-GT740U.. I have 4 gauge power and ground wire and the RCA wires that came with the wiring kit i got from D&B Audio. I have installed many systems and never had this problem before.
is it OFC wiring your using?
Could be something simple as wiring issues.
---------- Post added at 11:13 AM ---------- Previous post was at 11:12 AM ----------
Oh and check your battery voltage while vehicle is running with a dmm.
Smoker076
Smoker076
Warsaw, IN
Smoker076
