Phil m
Hello,
I want to power two 15" full range passive 8 ohm molded speakers. The speakers are rated 350 watts so I'm thinking I need a amp with 2 channels, 525 watts per channel @ 8 ohms, full range stereo amp, 12 volts only. I could run the two in parallel if that's the only opposition, 700 watts @ 4 ohms with a 1,000 watt mono amp but I want full range output. I don't want to use any kind of 110volt power inverters either and I like to have the level, treble and bass adjustment on the amp. I like to keep the price of the amp below $400
Any help would be greatly appreciated.
thanks, Phil
thanks, Phil
