F-Ranger
ok not the best when comming to amps but heres whut i need to know. I bought 2 12"W0's (JL AUDIO)
specs:
Nominal Diameter: 12 inches (300 mm)
Continuous Power Handling: 125 Watts
Voice Coil: 1.38" diameter, 6-layer, Kapton former
Available Configurations: 4 ohm or 8 ohm (Single Voice Coil)
Xmax (one-way, linear): 0.34" (8.6 mm)
Sealed Enclosure Range: 1.00-1.75 cu.ft. (28.3-49.5 liters)
Ported Enclosure Range: 1.75-2.75 cu.ft. (49.5-78.0 liters)
VRC™ Technology: YES
now i was wondering if the 2004 JL AUDIO E1200 MONO SUBWOOFER AMP would power my 2 12s?
Specs on amp:
Rated Power (mono):
120 W RMS x 1 @ 4 ohm (12.5V);
200 W RMS x 1 @ 2 ohm (12.5V)
THD at Rated Power:
S/N Ratio:
>104 dB referred to rated power (A-weighted, 20 Hz – 20 kHz noise bandwidth)
Frequency Response:
10 Hz – 25 kHz (+0, -1dB)
Damping Factor:
>200 @ 4 ohm / 50 Hz,
>100 @ 2 ohm / 50 Hz
Slew Rate:
± 22V/µs
Input Range:
200mV – 8V RMS
Dimensions:
9.8" x 9.25" x 2.36"
Features:
Absolute Symmetry™ Class AB Circuit (U.S. Patent #6,294,959)
Differential, Noise-Cancelling Input Topology:
RCA jack inputs (low-level) and multi-pin jack (high-level)
On-board Crossover:
State-variable, 12dB/octave Butterworth with continuously variable cutoff frequency selection from 50 – 200 Hz. Configurable as Low-Pass or High-Pass
Preamp Output:
Pass-through type.
Speaker output connections:
accept up to 8 AWG wire
+12V and Ground connections:
accept up to 4 AWG wire
THANKS! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
specs:
Specs on amp:
Rated Power (mono):
THD at Rated Power:
S/N Ratio:
Frequency Response:
Damping Factor:
>100 @ 2 ohm / 50 Hz
Slew Rate:
± 22V/µs
Input Range:
200mV – 8V RMS
Dimensions:
Features:
On-board Crossover:
Preamp Output:
Pass-through type.
