Help Please
travis420
Ok today i took out 1 of my subs to rewire it and after i put it back in when i hooked the power back up to the amp the speakers have a beat that dont stop like buzzz kinda non stop until i power the amp off. The beat has no flow with the music or nothing jus kinda a buzz beat but there deffently not blown ive checked the speaker tryed other speakers and it does the same thing every time but i hooked the subs up to my tweeter amp and they work fine wat could be the problem rca's? which ive moved around 2 make sure there not 2 close to the power wire in wat not. Any Ideas???? THanks
i thought about that but it had no problems at all until i did that and had no affect to the ground but ill prolly check that 2 morrow just incase
ok ive done everything that ive could done like hooked up another amp 2 the same wiring and it works fine with my subs so it must be the amp why would the amp be causing it 2 do that
travis420
travis420
Ohio
travis420
