help please fast in installing now, on wiring up fans
but either way it shouldnt make much of a diff. Its a fan if it changes speeds nothing bad is going to come from it
well the amp is 1000 rms and i just thought of something will doing this case the fans to run even when the amp is off because the power cable is a direct shot to the battery
Deff use a relay. The REM does not have the amp capacity to run fans. It it advisable to use a relay when running over 2 car amps. Wire the relay into the rem of the amp you want colled, and you can use that amps power/ground for the relay. That way it only comes on when that amp comes on.
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
pablo4429
pablo4429
san diego
pablo4429
    May 31, 2024
    May 24, 2024
