help please fast in installing now, on wiring up fans
well the amp is 1000 rms and i just thought of something will doing this case the fans to run even when the amp is off because the power cable is a direct shot to the battery
Deff use a relay. The REM does not have the amp capacity to run fans. It it advisable to use a relay when running over 2 car amps. Wire the relay into the rem of the amp you want colled, and you can use that amps power/ground for the relay. That way it only comes on when that amp comes on.
pablo4429
pablo4429
san diego
pablo4429
