Help on special wood cutting techniques...
Let me understand this one second, you cut out 8x10 elipses and you want to mount plexiglass actually in them by producing a lip for it to rest one? If so, just use a router with the proper bit.
you could always put the windows on the inside of the box. it will look bad on a painted box though, it looks good on a carpeted box though.
if you are talking about the fiberglass/bondo boxes that looks like parts of the car you can always make the plexiglass bigger than the whole glue it in so its inside the box but make sure you seal it up with some silicone and then ad some extra around the hole you cut in the mdf to make it more of a gradual transition.
149
361
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
341
585
beachboy016
beachboy016
Los Gatos, CA
nismboy6986
    May 12, 2024
Brendon Jenness
    May 11, 2024
