Help on a switch
Folly
i was gonna wire a switch to my amps so i wouldnt have to listen to bass all the time if i diddnt want to and also so i could cut it fast if a cop was to come by.......but im using 2 ga. amp kits so how could i wire a switch with the power wire being so big??? should i try it or just forget about it and do somehting else???? if anybody has an idea or suggestion let me know. thanks
my amp dosent have a remote for it so how would i go about doin it? my friends have theres wired in but they have an amp that is well less powerfull
i prob sound dumb but o well i would rather us both know what were talking about and be on the same page so one i can get help and 2 i dont get confused and anough u all
ok so do i just run a wire from the amp to a switch and then to what?? like i know where u talking about now the input for it is like where the ground and power is correct??
All amps have a connection near the power wires called Remote (or just REM) that goes to a small wire. That wire is a control signal that goes to your deck, and it turns the amp on and off. All you need to do is cut that wire and put a switch inline with it.
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
155
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
363
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
344
11
588
Folly
Folly
Los Angeles, CA
Hooter
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
