Help Needed!!!
ruffryda430
for some reason my speaker amp cuts out when i raise the volume. some long periods of time it'll work. then the next time i drive, the speakers will cut off when the volume is above 20 or so. i know i am not overpowering my speakers because the amp is an old Kicker Impulse model probably from the 90's and the wattage is enough for my pioneers. i'm thinking it could be the wiring somehow, what can be the problem?
Check your ground, make sure its good. Make sure you have good connections everywhere on the amp and on the wires from the amp. Be sure the ground has a solid connection on bare metal.
ruffryda430
ruffryda430
Fremont, CA
squeak12
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
