Help need a decision...
Fuknmovin
OK, I have been trying like hell to figure out what I need to do for my next box and thi is what I came up with so far, 35Hz, Sub forward, and port to the passenger side @ 4 cubes net...The problem is my space went down considerably for the box to sit on the pass side, I have only about 24-25" of space to deal with width wise and thats INCLUDING the port clearance so I figure about 17" is the max box width. That leads me to the next problem....not enough room for the ports to get the tuning with 4 Aeros (which I already bought) so I came up with this setup there is TOTAL smooth airflow and no resriction in the bend what do you think of this.....or should I start over and just do a slot port?? HELP!
-Thanks!
OK no responses, I can only imagine this means its a bad idea, I think I will go back to my original idea..
it's good to avoid bends in the aero's, but not pertinent. you should be fine with a single bend. i'm assuming that part of the port is outside the box.
Fuknmovin
Fuknmovin
Palm Desert, CA
Fuknmovin
