Help, my buddy would like opinions of everyone :)
Which?
  • Alphasonik
    Votes: 3 12.5%
  • Memphis
    Votes: 20 83.3%
  • Infinity
    Votes: 1 4.2%
  • Total voters
    24
SKyleS
He's getting a system, and he'd like to know what's the best fit for his vehicle. Here's his options for his 1995 Ford Explorer:
Amplifier: Memphis PRD1000.1
http://www.memphiscaraudio.com/products/details.asp?cat=&id=66&p=2
Sub Options:
1)Alphasonik (1 sub of the 800 series subs, not sure which)
http://www.alphasonik.com/800.html
2)Memphis PR (2 subs)
http://www.memphiscaraudio.com/products/details.asp?cat=&id=56&p=2
3)Infinity Series subs (2 subs)
http://www.pbnation.com/showthread.php?t=1587251
Which would be the best for that amp? Any opinions on that amplifier? How stable is that amp? Would a 1 OHM load draw to much of the battery and alternator? Thanks guys..
memphis a a way better brand than both, even though that series isnt thier finest, its still better //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thanks guys... It seems pretty close between the Alpha and the Memphis subs.
How is Alphasonik subs? Or at least that sub. It says it's 800/900w RMS.
Also that amp is 1000w at 1 OHM, I heard it eats a lot off the battery and alternator. Any truth to that? Better not to run off of 1 OHM?
get the memphis subs and amp, and 1000 watts should do ok on a stock electrical system, just to make sure you might wanna get a better battery and do the big 3 upgrade.
He's got a Red Top battery (because it's an SUV). SUV (Ford Explorer) have bigger alternators? I think.. not to sure though.
So if he gets the Memphis subs, run at 2 OHMS for 600w RMS to them, but if he gets the alphasonik, run it at 1 OHM for 1000w RMS?
Springy.....quantify what you are saying when you recommend that. If he takes the volume dial to full output, the amp is still going to make full power. The amp will make full power regardless of where the gains are set when the volume dial on the cd player is taken to the max. By your very words in your post, you are inferring that the gain control on the amp is a volume setting, it is most definitely not. The only way to get less watts, turn down the volume, decrease the input voltage or change the load. The quickest way to start damaging a speaker, incorrectly set the gain.
Springy.....quantify what you are saying when you recommend that. If he takes the volume dial to full output, the amp is still going to make full power. The amp wil lmake full power fegardless of where the gains are set when the volume dial on the cd player is taken to the max. By your very words in your post, you are inferring that the gain control on the amp is a volume setting, it is most definitely not. The only way to get less watts, turn down the volume, decrease the input voltage. The quickest way to start damaging a speaker, incorrectly set the gain.
we have already argued about this many times, if you have the gains turned all the way down, you wont get 1000 watts at full volume. im sorry, thats just not how it works. so in your mind what does the gain control do? and you say that the only way to decrease wattage is to decrease input voltage by turning down the volume, but the gain knob does the exact same thing it increases/decreases input voltage depending on your head units preout voltage to deliver the correct amount of power to your subs.
X2 thats why when u have ure gains all the way down u can crank ure volume and still no bass.
SKyleS
SKyleS
Canada
TheSpeakerMan
