Help me select sub for ram 3500 and prefab enclosure
I have a 2003 ram 3500, looking at a prefab enclosure http://www.foxacoustics.com/ProductDetails.asp?ProductCode=DQC-212-V 1.55ft3 ported tuned for 35hz I know this is probably not the best enclosure(or could be), but I have to conserve space.. The page says type R's fit, but do you guys know of a sub thats better/More power handling that I might be able to use with the available space and dimensions of this enclosure.. pretty open to amps, but I think I might try out a ba7000.1d or ba5000.1d depending on what subs I get.. I do have a kicker 2500.1 that i'll be pulling out of another vehicle soon if I dont like the ppi amp. So I'm looking for subs that are dual 2 ohms so I can take advantage of the 0.5 on ba7000.1d or the 2 ohm ok 2500.1 if necessary... Thanks for any suggestions..
oh forgot to mention, I do realize that if I do have to go with type r that all those amps would probably blow them, unless safely set below rated with dmm...
anyone know of a shallow mount sub, or a smaller sub in general that can handle 1000w rms that might work in this application.. I know shallow mounts tend not to be able to handle higher power..
1.55 cubes ported is small, and they don't say the port volume. This is a better designed and built enclosure: 2002-2015 Dodge Ram Quad Cab Sub Box Dual Low You get fiberglass tub construction and the plush factory matching carpet instead of Line-X. They also have a tall version of this enclosure with matching seat lift supports.
So if I went with the tall version of this box, what would be your suggestions for subs that might fit in the 1000w rms range?
Most companies offer a subwoofer that can work well in that enclosure. Do you already have an amplifier? How did you decide on 1000W RMS?
I'm going to temporarily use a ppi ba7000.1d. But I also have have a kicker 2500.1 that'll be available in about 2 months if I dont like the 7000.1. I came up with a 1000 rms because thats my power goal(2000 rms) truck has 2 batteries from stock, I'll be running kinetik hc 2400 in both locations, 4 or 500 amp alternator, big 3 upgrade with 0 gauge, possibly might add 2 battery bank in bed(hc-2400 tied in with 2/0 wire as I also have a very big inverter and winch.. this is my hauling truck, So i need power on demand, but want great sound also..
Alpine Type R will rock in the Net Audio Tall box. People run 1,000W RMS on those all the time. If you wanted to buy from us I can't get you Alpine, but I have other good brands.
I also just checked the voltage and the voltage on the amp in 12.85 and the rest of my stuff like my lc2i and remote out wire is 12.10. could that...
58
221
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
654
408
marvelouzone
marvelouzone
Baltimore, Md
marvelouzone
    May 18, 2024
    May 18, 2024
