hollywood084
To make a long story short, my D2 has been out of service for about 6 years and I'm looking to resurrect it. I'm no electronic tech, but I personally think (knowing the history behind the amp) it's either not receiving an audio signal from the HU (via the rca input jacks on the amp), or it's not pushing out the signal to the sub from the speaker output part (no power or something.) I really don't think it's anything between there, but I won't rule anything out since I don't know a whole lot.
One of the parts in question is the one right between the two gold speaker outputs, in front of the big orange thing. Now apparently, if I remember correctly (it was 6-7 years ago) the guy who worked on it says he cut it (for some reason, to test something I think) but it shouldn't be the reason it's not working at all now. Quick note, the amp worked BEFORE I sent it to the guy, when I got it back it didn't work at all.
Apparently the only part that was worked on/replaced is the RCA inputs (to the left in one of the above pics.) Is there any way I can see if the amplifier is receiving a signal through those?
How I can test with a multimeter to see if the amp is pushing out power through the speaker outputs pictured above, to the sub.
As far as I can remember, the amp did NOT go into protect mode when hooked up.
Thanks in advance. Any help is greatly appreciated.
//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
