help me port
Chance89
CrAsHiNg *****
Can you guys help me port my box. It would have been done a while ago but its so thin I didn't wanna try. I got two 12in pioneer TS-W304f's in a box.don't exactly know what I want to tune it @ I'm thinkin 33hz
-7in top depth
-10in b depth
-60in long
-and 17in high
I don't understand the formulas...whats vb? and addl v?and there's a bunch of other stuff to //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
can someone teach me to use these designer's or tell me where to place and whats size the port has to be
I use ajdesigner.com
Vb= the reqired internal volume of the enclosure
F3= the frequency that the response is down by 3 db at
Fb= the frequency that the vent needs to be tuned to
Vas= the equivelent stiffness of your driver
Fs= the free air resonance (this is your tuning frequency its a good rule two build it a few Hz higher than what your drivers requier because if you dip below your driver Fs the sound will get muddy.
to calculate your
Vb=Qts^(2.87) x 15 x Vas
Fb=Qts^(-0.9) x 0.42 x Fs
F3=Qts^(-1.4) x 0.26 x Fs
To port you are going to need these specs: Vb, F3, Fb, Vb, Qts, Vas, Fs, Xmax,
the required volume for each driver, the diameter of port you are using (inside diameter) Find these out and i will do the math. i just figured this stuff out with the use of some calculaters. what program do you use?
Becareful useing calculators. They are not all accurate. If you know the formula, use it to check the calculator....but then I guess if your going to do that you may as well not use the calculator....? Nevermind...
Just becareful which ones you use.
that is the one i use however the calcs at the 12 volt are a little easier to use and you get the same answers chance how many drivers you running i cant remeber. hay trixter thank s for all your help on my porting ill be building it this weekend. cause its raining like a b!tch now for the last few days. i cheked the math and i can do most of it on paper and it is slightly more acurate. learned alot from you thanks. tty later
Chance89
CrAsHiNg *****
Chance89
Alberta
ky babyn
