help me please!!!!!
  • 2
pmpdoutaltima
ok, Im needing 4 cu.ft. for my 2 12's, the box is gonna be ported with a 4 x 16 in. round port. Its gonna be 1 single box. If I build it 37x15x20, it will be 5.13 cu.ft. (interior), how much will it be after subs and port displacement. Will it be atleast 4 cubes. Thanx:D
based on the information you gave, its gonna be a bit hard to answer that question accurately. I would say you are in the ball park
Originally posted by pburt based on the information you gave, its gonna be a bit hard to answer that question accurately. I would say you are in the ball park
what else do you need to know, the wood will be 3/4 MDF of course, 2 12 inch Memphis Audio power reference, a 4 inch round port. Please, somebody should know, Im starting on it tomorrow or Friday. Thanx guys
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
954
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
pmpdoutaltima
pmpdoutaltima
Cullman, AL
pmpdoutaltima
    May 16, 2024
    May 16, 2024
