Help me Please with Speakers
  • 2
tuca33
I have a kx 500.2 amp for the speakers and i have a boston acoustics pro 6.5 kit,,and i will like to add another component set..
my bostons will be placed at the door mount of the dakota and the other kit i am planning to buy will stay at my feet,in a custom made box pointing upwards..
so the sound waves will cross one another,,and i was afraid of having fase problems..
people said me i only should buy more speakers if they were identical,,but i was planning to use a boston rally 4 inch component set(because the pro line is too expensive)
My amp loads at 2 ohms and the kits are 4 ohms each so i can use 1 or 2 kits that i will have the same power,,am i right???because the impedance will fall if i wire the kits in parallel..
thats it???
If i plan using another component set kit,,i should use the boston pro,,or i can mix brands(or models,,in the case of the boston rally))..
The impedance dropping to 2ohms will harm my sound(like SQ???
Can i buy the rally kit with my eyes closed(they are rated 90 rms and the pro 150 rms(but as my amp will deliver 125 per channel i think i will not overpower my rallys(like i think it will not distort before the pro..or am i wrong??
Thanks and apreciate any help
Mixing brands and types is not a problem. Yes, two 4 ohm sets in paralle will be 2 ohms and that's not a problem either. Boston's have a good rep buy I haven't (yet) owned any so I can't comment on how they'll sound.
That is strange there. Thats what Ive encountered with low voltage before . That Kenwood needed a Firmware update and that fixed that one when it...
17
Were the speaker ohm-loads the same from factory to the JBLs? That "may" play part. Some head units with 4 to 8 ohm stock speakers really dont...
I just swapped out my factory speakers for JBL speakers in my 2012 Jeep Compass. Initially, the speakers did not work. Then, after shutting my car...
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
tuca33
tuca33
Rio de Janeiro,RJ
maylar
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
