comptonsmw
So I told a friend of mine that I could help her install an aftermarket head unit thinking I had the capabilities to figure it out, I was wrong! I got it all hooked up how the wiring harness adapter showed, we plugged it in, turned the key to on and it worked! Then when she started the car up it died, we tried 3 or 4 times and it started then died each time. I thought it was something with the battery so I cleaned the positive and negative terminals and still no luck. So then we tried jumping her car with mine and even that didn't work. Just for the heck of it I disconnected the new radio and then we tried again and everything was fine, it started and stayed on. So I'm guessing the problem is in the wiring of the new head unit somewhere I just don't know where to look. I redid all the connections between the adapter and the harness going to the head unit so I doubt that its a loose connection. I did hook up the ground to just the same factory ground and nothing else, would that cause this?
She drives a 2005 Dodge Neon and the head unit is a JVC KD X200. She got it from SonicElectronix with the dash install kit and wiring harness adapter that the site said she needed.
A quick recap-Her car starts then dies with new head unit connected. With no head unit or with the stock one it works fine.
Any help would be greatly appreciated!
