help me out im newb
i would recommend my system if you are looking for some SQ.
Image Dynamics IDQ v.3 12 inch d4 - $280
Ported Box - make your own if you know how to and have the tools -around 50 bucks
Amp - Alpine pdx 1.600 - 250 or so
Component speakers - Everybody here rave about rainbow slc 265 - 250
Amp - Diamond Audio d3 400.4 - 150 or so
a little over 900 for everything but not including wires, installation, etc
you could also change the amps if you want. i just recommended what i got but there's other amps out there for cheaper
Two amps for those two subs? No it wont work. One amp those subs? yes but they would be getting less than 250w. Those two amps with 2 dual 4 ohms? Yes that is the route I would recommend out of the equipment you are looking at.
there are plenty of good "500 rms at 2 ohms" amps.
kicker zx 500.1 - 220
alpine m500 - 150
phoenix gold x600.1 - 200 or so
alpine mrp m600(something like that) - 180
alright so il change the type r's to the 4 ohm ones. i searched the sae-1000d amp and it only puts out 300watts at 4ohm wouldn't that be too little for the type r's?
what about the Alpine MRP-M850 which puts out 500watts rms at 4 ohms? would 2 of those be good?
I don't think you understand how impedance works. A pair of DVC 4 ohm drivers can be wired down to 1 ohm. Most amplifiers produce more power at 1 ohm. Trying to run a pair of Type R's at 4 ohms would be a waste of your money.
Also look into Pioneer 3000SPL's. Solid budget subs that are designed to get loud in relatively small enclosures //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
p.s. http://www.bcae1.com
xsupermario
xsupermario
chicago, il
Alpineforever
