help me!!!!!! my solo X sounds like shit!
joep1231026
CA
after blowing a piece of shit polk mm 12" with single 4ohm, i decided to stop clowning myself....
i have a sundown saz-3000D mono amp, and i purchased a brand new solo X 12" with dual 2ohm coils. I have a 1.5 cube sealed box, and 0g kolossus fleks cables, 12g hyperflex speaker wires.
wired in series, the sub sounds OK, but is just not nearly the power i paid for...
wired in parallel, the sub sounds good when it only has a little power, but when i turn it up, the sub makes a popping noise.
is this clipping?
what is my problem? can the box only power ~800W to the sub?
i'm hoping all i need to do is get a good ported box, but i have no clue whats wrong... also, i have 2 batteries with 200A alternator.
please give me any and all advise, im a ****in n00b.
i just want my solo X to make my ears bleed, but its not even close...
Itl give the sub clean power. Allowing it to (probably) get louder without hurting it or producing the pop perhaps.
Read a gain setting tutorial. Or as a quick test use the old method. Turn the gain down, set volume knob to a casual listening level. Slowing turn the gain up until the sub stops getting louder, and turn it back down a little.
That should get you in the area of right if you dont have a DMM. Try that and let us know how it goes.
so i guess the question is.... sell the solo X or buy a 3 cube ported box?
... even with the gain almost at the lowest setting possible, when the volume is turned up the sub still pops.
joep1231026
joep1231026
CA
hatedonmostly
