Help me friend yo homeboys
more_spl
only have 1, but it's 12"
ok, my friend has a ROAD THUNDER amp //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
he did some tweaking on his set up, and now his HU and amp don't work //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
when he turns the system on by his kill switch, the amp goes right into protection mode. he left wiring the same, the amps not hot, he made a newer ground (a good one) and the voltage is prolly what it normally is, so what else can be wrong !!
he also said no wires looked crimped or busted up. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Originally posted by more_spl ok, my friend has a ROAD THUNDER amp //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
disconnect the load on the amp[speakers] and power it up---if it goes into normal mode ------look at the wiring-- if not itest the power-ground-remote with a volt meter. If the power is good then check the fuses ON the amp. If they are good then the amp is screwed
more_spl
more_spl
Winnipeg
chris229
