oTurtlez
Ok, so I decided to amp my front door speakers and I finally got everything fabbed and put together so I could install my 4 channel amp. Got all the wiring ran and went to hook the positive up and when I touched the battery terminal with the ring connector, there was a spark. Happens every time, I'm used to it, checked my inline power cable fuse, no blow, decided to bolt the cable on. Got everything all set up, had my ground running to the same bolt as my other amp, flipped my turn on switch, my mono powered up by the 4 channel didn't. Checked all fuses and sure enough. one was blown on the amp. I went to put a new one in, forgot to disconnect the amp, and got a nice arc to the new fuse. Fuse didn't blow so I disconnect the ground (mistake #2 ) and plugged the fuse in. Went to plug the ground back in, got an even bigger arc, and it blew both of the fuses in the amp. I'm out of fuses so I have to run and pick more up today and see if it's a short somewhere, which is has to be. Going to test the amp on my bench to see if it still works, hopefully. I have no idea where it could be shorting out. No damage to my power wire, all voltages are fine back at both amps, just the second I put a fuse in the 4 channel in my car, it blows it. If anyone has any good ideas as to what's happening, I'd really appreciate it.
EDIT: I currently only have a 50A fuse for my power wire, not sure if that's a cause.
