cHaMoRrO_GiGoLo
i've decided i'm going to get 2 12" re sx's and now i need an amp that puts out at least 2k watts. the three above are the amps of choice, but if any of you some other suggestions, feel free to add them as well. basically all i want to know is which amp would be better (overall quality and sq)? please give your best recommendation. also, i do not want to spend no more than $700 on the amp.
here are some specs:
orion 2500d orion website
Max Power 2500
4 Ohm Rating 1200 x 1
2 Ohm Rating 1700 x 1
1 Ohm Rating 2500 x 1
Mono Rating - - - -
Freq. Resp. 20Hz - 300Hz
THD+N
Damping factor > 50
Signal to noise ratio > 80
Crossover range/scope LP 30 - 250hz 12/24 db octave
Input sensitivity 200mV - 5V
Safe load impedance 1 ohm
Equalization Circuit 10 db Intelli Q
Amplifier protection* T,D,R,S,O
Externally Bridgeable No
Dimensions** 27.2"L x 10.5"W x 2.3"H
*T - Thermal protection, D - DC offset protection, R - Reverse polarity protection, S - Short circuit protection, O - Over/under voltage protection
* All power ratings are @ 13.8VDC supply Voltage, all channels driven
** Amplifier dimensions are for heat sink only; add 2 1/2 inches per side to allow for end cap installation
planet audio vx2200d planet audio website
Max Power (1 Ohm) 2250W x 1
Max Power (2 Ohms) 1750W X 1
RMS Power (2 Ohms) 1200W X 1
RMS Power (4 Ohms) 800W X 1
Signal-to-Noise Ratio 100dB
Frequency Response 20-250Hz
Dimensions: 10-5/8”W x 2-7/16”H x 18-3/4”L
Includes:
RM15 Remote Subwoofer Level Control
DataLink Cable for Strapping Amps Together (2 Ohm Only)
hifonics xx hercules hifonics website
4-Ohm Power Rating 1x650
2-Ohm Power Rating 1x1300
1-Ohm Power Rating 1x2000/2kW
System Configurations Possible 1-Channel
Miscellaneous Specifications
Turn-On Delay/ Mute Yes
Frequency Response -3dB 2Hz to 250Hz
Damping Factor > 400
Signal To Noise Ratio > 98 dB
THD + Noise
Variable Input Level Contol (RCA/Unbalanced) 0.2V - 9V
Variable Input Level Contol (Mini DIN Balanced) 0.4V - 18V
Variable Input impedance (RCA/Unbalanced) 0.6k - 47k-Ohm
Input Impedance, Balanced 20k-Ohm
Hi Output Whisper Fan No
Power and Specific Diagnositics LEDs Yes
Protection DC, Short Circuit, Overload Yes
Power Supply - All MOSFET Full PWM
Power Output Circuit Type Ultra-Fi MOSFET
Subsonic Filter, 12 dB Stereo, 24 dB Mono 10Hz - 150Hz
Phase Change in Degrees 0 - +180
Variable Low Pass 24 dB Octave 35Hz - 250Hz
Subsonic Filter 10Hz - 50Hz
Bass EQ 30Hz - 60Hz
Bass Boost 0 - +18 dB
Connector Types
Balanced Inputs (DIN) for Optional XX BLD Line Driver Yes
Unbalanced Input (RCA) Yes
Line Output (RCA) HP/Full/BP High-Pass
Bridged Input (RCA) Yes
Bridged Output (RCA) Yes
Remote Bass Module Included (Via RJ11 Jack)
Mechanical
Gold Plated Power Terminal Blocks 2-GAx2
Gold Plated Speaker Terminal Blocks 10-GA
Dimensions - WxHxL (Inches) 11.10x2.75x22.83
Max Power 2500
Mono Rating - - - -
THD+N
Damping factor > 50
Includes:
THD + Noise
Bass EQ 30Hz - 60Hz
Connector Types
Mechanical
