Help me choose
It's simple I already explained how music taste do NOT determine your enclosure. He says he listens to only lows so does that mean all he has is subwoofers and no mids or highs? Of course not it means he has no idea what he is talking about, and thinks that the only bass in songs is 30hz and under.
Or maybe it means he doesn't like songs with high bass? I know plenty of people including myself and Buck who personally can't stand anything over 50hz, hence why our boxes are tuned
Or maybe it means he doesn't like songs with high bass? I know plenty of people including myself and Buck who personally can't stand anything over 50hz, hence why our boxes are tuned that is stupid, leaving out en entire section of bandwidth because your poor little ears can't handle it.
No, it's that way so I can play down to 20hz and not have to worry about the sub unloading nearly as bad as if it was tuned higher. There's a reason I've remixed 20+ songs to have lower bass lines. Everyone has different listening tastes.
I would try to explain it but I doubt you would understand.
Please explain to me how liking songs with certain frequencies doesn't determine what you want in a box? I like songs with low bass, I could give 2 shits about higher bass, but going by your logic it doesn't matter what box I get since my music taste has nothing to do with it.
Guys, just trying to buy subs here no need to argue !!!
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
again, with the SA-15, DO I need a extra battery!??!?!
your electricals arent based off your sub(s). they are based off your amp.
Okay thanks guys //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
and also, i have come to the concluison.
either:
1x sa 15's
2x sa 12's
which one should i pick? i may get a single sa 15 then get another and sepearte box later down the road.
Edit: think i will go with 1x sa 15's with a custom box, what amp would be good for just 1 sa 15 ?
either:
1x sa 15's
2x sa 12's
FINE DONT BUY MY STUFF, I SEE HOW IT IS YOU @SS!
lol jk. i wasnt kidding when i said i dont care.
personally id go with the 2 sa-12s. more cone area. but if you want a single sub, the sa-15 would be nice.
between those, its really YOUR decision. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
good luck either way with your setup, good to see youre doing it right the first time
also, i just read your post. my amp would be good. lolol //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
or if im going to go with 1 sa 15, should i consider something else if i am just purchasing 1?
---------- Post added at 08:43 PM ---------- Previous post was at 08:42 PM ----------
haha well i think your sub is better than the sa-15 , so i will think about it. still doing research //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
decided on a single a-15 , what amp for just a SINGLE 15, and any preferences on boxeS? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
pro-rabbit for a box build, ram_designs for a design if you wanna build it yourself. How much you got to work with for an amp?
mehh id spend around $200-$300 for the amp, sub itself is $250 it looks like ( as i should get 4ohms i am guessing )
and if i build it myself :O what is needed? ( links are loved ) guides etc
Tek18
Tek18
KY
fullwoofer2121
