Hundreth
I am telling you to set the lpf on the amp lower, not the headunit...with my headunit, i cannot set it lower than 80. Its either full, 80, 120, or 160. And with the wiring, how hard will that be to switch the wiring? Will i have to rip the car apart again? Or are you just saying just unplug both power wires and switch them with eachother?
It should be very easy for you to switch the power lines between the two amps, just unplug, switch them around, plug back in //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Also, how is the signal reaching your Nine.1, are your amps daisy chained? does your Nine.1 have its own set of RCAs or is it chained to the Nine.2?
If its going through the Nine.2 first, you might want to check the Line out settings to see if you are getting the correct signal, I have a feeling that could be an issue with you since you say that there was a difference after they installed that amp.
If they aren't daisy chained, try disconnecting the nine.2 and run the nine.1 alone and see if there is any difference.
Let us know so we can fix this crap //content.invisioncic.com/y282845/emoticons/2thumbs.gif.fdc3ba010dbb42b61704534b46d02fe4.gif
